Why is local hosting of ArcGIS Online webmap giving error?
I have been trying to locally host this webmap I created using AGOL (to modify it):
http://dpwh.maps.arcgis.com/apps/MapTour/index.html?appid=7bd06d8330254b2688577d82f81bb92e
It uses the Map Tour template. I did step 1 of the readme file, and since I already had built the application inAGOL, skipped to step 5 and configured configOptions to use the appid, such as it now looks like this
configOptions = { // Enter either a web map ID or a web application ID // - Using a Map Tour application ID created through the interactive builder in ArcGIS.com allow to reuse // the settings like the header configuration without having to edit any configuration here // - Web map and application can be dynamically specified through url parameters (webmap and appid) // if the authorizedOwners property is specified (see below) // - If an application id is specified, the webmap configuration isn't used webmap: "", appid: "7bd06d8330254b2688577d82f81bb92e", // Optional list of authorized application or web map owners // Has to be specified when using appid or webmap url parameters (e.g. ["user1"], ["user1", "user2"]) authorizedOwners: [""], // Select the application layout between "three-panel" and "integrated" layout: "three-panel", // The application header title, if no title is specified, the webmap's title is used title: "", // The application header subtitle, if not specified the ArcGIS.com web map's summary is used subtitle: "", // Optionally force a web map layer to be used as the tour points data source (can be overridden through URL) // Otherwise the upper visible point layer is used (excluding map notes) sourceLayerTitle: "", // Use the first data record as an introduction instead of a point (can be overridden through URL) firstRecordAsIntro: true, // Optional zoom level to be applied for the story points following introduction (can be overridden through URL) (e.g: 0 to 16 for Gray Canvas, 0 to 19 for Street Map, -1 to disable) zoomLevel: -1 };Loading the local version however only produces a "Fatal error: Failed to get portal configuration" error. This is the case even if I only use the webmap id, or just load the page unmodified.
Help please to make this work?
