I am a beginner in GIS, more specifically Geoserver used with ESRI ArcGis, and here is my problem:
When I run a gs:Clip WPS on a layer with points, some of the objects it gets from the oracle database are unknown and some are good. For example:
The unknown object:
minx: 7540000.25miny: 460000.88maxx: 7577010.9098maxy: 4609904.67As you can see, the min and max point don't match (the max point is different from the one in the DB), and since this is a layer of points they definitely should. The data in the DB is completely fine and there the points match.
What might be the reason behind this?
The unknown object:
