Why does the "calculate" button remain gray in Group Stats Plugin?
I'm trying to use the Group Stats Plugin. I found your tutorial and I wanted to post a comment but I have seen that it is not possible then I thought to write here.Unfortunately I can not use the plugin: after I enter all the required values, press "calculate" is not active and is always gray.My problem is that I have a shape of point that are points for animal sightings. This shape is formed by a text field containing the types of areas (beech, poplar, etc.) and another containing the areas value.I need to calculate the number of records that contains a precise type of vegetation and the sum of the relative areas.
This is possible with Group Stats Plugin?
Thank you very much!
