Why does "takes no arguments" error propagate from Arcpy example?
I was attempting to run Setup_Customers_Using_Tabular_Data , I modified the paths to fit my environment but when I run the program I receive
SetupCustomersByTable() takes no arguments (6 given) note: I had to modify the exception clause to output this
A little investigation in IDLE showed this:
IDLE 2.6.5 >>> import arcview >>> import arcpy >>> print hasattr(arcpy.ba, 'SetupCustomersByTable') Traceback (most recent call last): File "", line 1, in print hasattr(arcpy.ba, 'SetupCustomersByTable') AttributeError: 'module' object has no attribute 'ba' >>> print hasattr(arcpy, 'ba') False >>> arcpy.ImportToolbox("C:\Program Files (x86)\ArcGIS\Desktop10.0\ArcToolbox\Toolboxes\Business Analyst Tools.tbx") >>> print hasattr(arcpy, 'ba') True >>> print hasattr(arcpy.ba, 'SetupCustomersByTable') True >>> import inspect >>> print(inspect.getargspec(arcpy.ba.SetupCustomersByTable)) ArgSpec(args=[], varargs=None, keywords=None, defaults=None) This is not the only function this happens with, but all of them in the BA package.
I've never gotten any full arcpy tutorial to work from the website, am I missing something obvious setup wise?
