Brand new to all of this, not even sure this is the right forum to ask in...
I have a client who wants to visualise cancer incidence and mortality rates by local/unitary authority across Great Britain. I've used Ordnance Survey data to get the boundaries of the authorities in GML format and saved all of them as one large GML file. I used QGIS to convert the data to KML format. I have the data in Fusion Tables now and it all looks great except for one blatant gap in the coverage.
When I look at the KML data for the missing local authority, it hasn't imported at all (ie the cell is empty). I've tried re-uploading the geometry (and re-downloading and re-converting) and Fusion Tables is definitely rejecting it as KML. I've read somewhere that Fusion Tables can mess around with your geometry somewhat, so I uploaded the KML file and pointed Google Maps directly at it and that didn't work either (I don't know how good a test that is).
I don't know that I originally created a valid GML file (I don't know the standard) but they seemed to import ok to QGIS and the final result looks great apart from this one place. The area is visible in QGIS when I load the GML file, so I don't know if QGIS is producing invalid KML, or mayble Google Maps/Fusion Tables have limitations?
Edit:I've downloaded the OS Open data pointed to by nhopton, loaded the appropriate layer into QGIS (Layer -> Add vector layer), saved it as KML (Layer -> Save as) and uploaded it to Fusion Tables. (Note that I didn't explicitly do anything with the CRS). Generally it's worked well (and importantly the particular area that had failed with my first method worked with this, so I have the missing geometry!). However, there's a number of missing areas again. And in this case, there's much less that I've done to the data myself, so it's not so easy to assume I've just messed up the data. Any ideas why my final results look like this?
I'd really appreciate some guidance from anyone who knows this area a bit better TIA
