Why can't Basemap's readshapefile read the world_adm0 shapefile?
I'm using the world shape file that can be found at https://trac.openstreetmap.org/brow...ixes/share/world_shp/world_adm0.shp?rev=17052.
import pysal as psimport ogr, osrimport shapely.geometryfrom mpl_toolkits.basemap import Basemappolygons = ps.open('world_adm0.shp')# from http://gis.stackexchange.com/questi...from-shapely-geometry-no-feature-added-error# create the shapefiledriver = ogr.GetDriverByName("Esri Shapefile")ds = driver.CreateDataSource("outputlocation.shp")layr1 = ds.CreateLayer('',None, ogr.wkbPolygon)for polygon in polygons: sh_poly = shapely.geometry.asShape(polygon) # create ogr geometry polylyr = ogr.CreateGeometryFromWkt(sh_poly.wkt) # create the field layr1.CreateField(ogr.FieldDefn('id', ogr.OFTInteger)) # Create the feature and set values defn = layr1.GetLayerDefn() feat = ogr.Feature(defn) feat.SetField('id', 1) feat.SetGeometry(polylyr) layr1.CreateFeature(feat)# close the shapefileds.Destroy()map = Basemap(width = 2000000, height = 1500000, resolution = 'l', projection = 'aea', lat_1 = -23, lat_2 = -32, lon_0 = 25, lat_0 = -29)map.readshapefile('outputlocation', '', drawbounds=True)results in:
ValueError Traceback (most recent call last) in () 33 34 map = Basemap(width = 2000000, height = 1500000, resolution = 'l', projection = 'aea', lat_1 = -23, lat_2 = -32, lon_0 = 25, lat_0 = -29)---> 35 map.readshapefile('outputlocation', '', drawbounds=True)
/apps/python/2.7.6/lib/python2.7/site-packages/mpl_toolkits/basemap/init.pyc in readshapefile(self, shapefile, name, drawbounds, zorder, linewidth, color, antialiased, ax, default_encoding) 2144 info = (shf.numRecords,shptype,bbox[0:2]+[0.,0.],bbox[2:]+[0.,0.]) 2145 npoly = 0-> 2146 for shprec in shf.shapeRecords(): 2147 shp = shprec.shape; rec = shprec.record 2148 npoly = npoly + 1
/apps/python/2.7.6/lib/python2.7/site-packages/mpl_toolkits/basemap/shapefile.pyc in shapeRecords(self) 541 shapeRecords = [] 542 return [_ShapeRecord(shape=rec[0], record=rec[1]) \--> 543 for rec in zip(self.shapes(), self.records())] 544 545 class Writer:
/apps/python/2.7.6/lib/python2.7/site-packages/mpl_toolkits/basemap/shapefile.pyc in records(self) 513 f.seek(self.__dbfHeaderLength()) 514 for i in range(self.numRecords):--> 515 r = self.__record() 516 if r: 517 records.append(r)
/apps/python/2.7.6/lib/python2.7/site-packages/mpl_toolkits/basemap/shapefile.pyc in __record(self) 478 value = float(value) 479 else:--> 480 value = int(value) 481 elif typ == b('D'): 482 try:
ValueError: invalid literal for int() with base 10: '**********'
What exactly has gone wrong with writing the polygons?
