where is the sequence in Oracle associated with the Objectid field in ArcGIS, and how
I am working in ArcGIS 10.1 with non-spatial Oracle tables. These tables have a field named 'objectid' because were created originally for inserting/updating records by using ArcGIS instead, not oracle. However, my goal is being able to use SQL developer for inserting big loads of data, but I cannot handle the sequence associated with the ArcGIS field objectid as it is controlled by SDE now. The tables are already registered with the Geodatabase.
My question is where in the system is this sequence stored, I cannot see it in my schema's sequences by using SQL Developer.
How could I add records to the tables either by using ArcGIS or SQL Developer depending on my needs?
