The navigation apps we carry around in our smartphones may have made getting lost in foreign lands a distant memory, but our dependency on the Global Positioning System (GPS) runs far deeper than we realize.
GPS satellites, owned by the United States government, carry onboard the atomic clocks that maintain the time standard followed by the world – Coordinated Universal Time (UTC). And accurate timestamps are crucial for the smooth functioning of everything from electric power grids to high-speed financial transactions where each millisecond translates into millions. Even the Internet service you are using to access this blog relies on precise GPS timestamps to route data, as do all digital communication systems.
So, if the GPS were to fail, the ramifications would not be limited to airborne flights and the ships at sea finding themselves isolated from the rest of the world. Armies would lose all control over drones monitoring natural disasters or surveilling terrorist outfits. Weather forecasts would be totally off and digital television and radio will not be able to continue transmission. Essentially, a total collapse of GPS could wreak havoc on a large number of systems intrinsic to the smooth functioning of our lives.
Reports from several parts of the United States and Canada said police, fire, and radio equipment was not functioning, and anomalies were detected in power grids. What’s even more mind-blowing is that the slip resulted in BBC digital radio going kaput for two whole days!
At least the error was unintentional, right? Right. But today, the problem of intentional GPS disruption is becoming more and more widespread.
In 2009, GPS interference was detected around Newark airport, compromising the air traffic controllers’ ability to receive precise location information about airplanes. An investigation revealed that the disruption was caused by a truck driver who was using an illegal GPS jamming device so his employer couldn’t track his whereabouts. A similar device used at a wrong place could affect maritime navigation as well.
And let’s not forget nature. In 1859, the world witnessed a solar storm so strong that if it were to take place today, it would knock out all satellites orbiting our planet. Known as the Carrington Event, after the name of the astronomer who discovered it, this superstorm was powerful enough to cause severe geomagnetic disturbances on Earth and send telegraph systems into a tizzy. NASA even reports, “Just before dawn… skies all over planet Earth erupted in red, green, and purple auroras so brilliant that newspapers could be read as easily as in daylight. Indeed, stunning auroras pulsated even at near tropical latitudes over Cuba, the Bahamas, Jamaica, El Salvador, and Hawaii.”
So, are we doomed by our deep-rooted dependency on GPS? Not necessarily.
[h=3]The way out: GPS alternatives[/h]For starters, several nations have built their own satellite navigation systems to rival the US-owned GPS. Russia’s GLONASS, China’s BeiDou Navigation Satellite System (BDS) and the European Union’s Galileo operate at a global level, while India and Japan have developed regional navigation and augmentation systems.
Atomic clock failure, however, is a problem that has plagued these systems too. Last year, nine clocks across 18 Galileo satellites in orbit stopped working without warning. India, meanwhile, has reported the failure of seven of the 21 clocks it has in its constellation of navigation satellites.
And let’s not forget that the signals from these satellites can be jammed too. Which highlights the need for non-satellite-based alternatives…
For years, the US Coast Guard used a land-based radio navigation system called Loran-C. That system became obsolete once GPS was widely adopted, but there’s no reason why an upgraded version of the same cannot serve as a promising backup. South Korea is reportedly already developing such a system and the US wants to follow suit.
Another option could be ground-based fiber optic cables. In a recent experiment, the US Department of Commerce’s National Institute of Standards and Technology partnered with the Naval Observatory to test signal transmission between two federal time scales. The results showed that the official world timescale (UTC) could be transferred with a stability of less than 100 nanoseconds, so long as the connection was not broken.
Well, one thing is for sure, without navigation satellites, the world as we know it will look like a very different place. And while the utter and complete failure of GPS may only be a dystopian scenario, it never hurts to have a Plan B in place.
The post What would happen if GPS failed? appeared first on Geoawesomeness.
