What simple and light Java library to use for WGS84 to UTM conversion?
Geotools and Geotoolkit are huge and complicated.
CTS (1.3.3 from Maven) failed on me by not even being able to run its own test example (slightly modified https://github.com/orbisgis/cts/blob/master/src/test/java/org/cts/op/EPSGTransform.java gave me "This registry EPSG is not supported" while I did not even touch those strings).
So, are there any alternatives that are easy to use, not require additional libraries if possible (even loggers are annoying enough) and are free software?
All I want to do is turn some WGS84 coordinates to UTM32N (EPSG:25832) in Java.
