What kind of operation will merge attributes from a point with a containing polygon?
I need to develop a process for merging the attributes of each point in a SDE feature class with a polygon in a SDE feature class that contains the point to create a third feature class. The third feature class should contain the attributes of the point with the geometry of the polygon. This seems to be a spatial join. Is that assumption correct?
The points represent incident locations. The polygons represent counties. The team is requesting I intersect the incident with the county to create the third feature class. There will be multiple incidents per county so they expect to see a row for each incident and the county geometry will be repeated.
I've been using ArcToolbox > Analysis Tools > Overlay > Spatial Join. Setting the Target Feature to the incidents layer and the Join Features to the counties layer yields the correct number of rows but the geometry is a point. I need a polygon. Switching the Target Feature and Join Features yields the correct geometry but not the correct number of rows.
How should I be approaching this?
