I want to know that what is the type of projection (900913, 4326 or so on..) of long/lat co-ordinates. I happen to come across a slight confusion while querying planet_osm_lines when I dump (St_DumpPoints) LineString into point and trying to get long/lat from that point. In the following code, I tried to transform into longitude using 900913 and 4326 projection. I realized that 4326 give me correct result while 900913 give the same as point value.
So, my question is, is 4326 default projection value for long/lat? i.e. any long/lat data that I get from, such as smartphone, or other device are in form of 4326?
In addition, while computing (st_distance, st_closestPoint etc.) the lat/long co-ordinates with the database 900913 based co-ordinates do I have to change it into 900913 projection? such as:
ST_Transform(ST_SetSRID(ST_makePoint(long, lat),4326), 900913);COde:
osm=# select d.osm_id, d.name, st_x(st_transform(st_setsrid(d.a,900913),900913)), st_y(d.a) from (SELECT osm_id, name, (ST_DumpPoints(st_astext(way))).geom as a FROM planet_osm_line limit 1000) as d; osm_id | name | st_x | st_y -----------+-------------------+------------+------------ 328454927 | | 9310610.35 | 3223602.19 328454927 | | 9310606.6 | 3223579.35 328454927 | | 9310597.74 | 3223554.21 328454927 | | 9310590.81 | 3223541.52 328454927 | | 9310591.28 | 3223530.75 328454927 | | 9310593.43 | 3223519.49 328454927 | | 9310593.43 | 3223495.79osm=# select d.osm_id, d.name, st_x(st_transform(st_setsrid(d.a,900913),4326)), st_y(d.a) from (SELECT osm_id, name, (ST_DumpPoints(st_astext(way))).geom as a FROM planet_osm_line limit 1000) as d; osm_id | name | st_x | st_y-----------+-------------------+------------------+------------ 328454927 | | 83.6386358188641 | 3223602.19 328454927 | | 83.6386021320409 | 3223579.35 328454927 | | 83.6385225413067 | 3223554.21 328454927 | | 83.6384602880575 | 3223541.52 328454927 | | 83.6384645101394 | 3223530.75 328454927 | | 83.638483823918 | 3223519.49 328454927 | | 83.638483823918 | 3223495.79I would be very helpful to have a clear understanding on these confusion from you guys.
