The instructions here: https://hub.qgis.org/wiki/17/Arcgis_rest are straightforward, but I'm getting the same 1000 features regardless of extent (with the 1000 feature outside the viewable map extent in QGIS). My current map extents should only return back a handful of features. Does QGIS pass in the map envelope as Input Geometryto the ArcGIS REST Service? Or am I expected to add it?
I am using the method where you take the http:///arcgis/rest/services//MapServer/ and add query?where=objectid+%3D+objectid&outfields=*&f=json to it. And then adding that via Adding URL as a Vector File in QGIS.
Is this expected behavior? And I need to provide additional query parameters to bring down by return features?
QGIS version
2.10.1-Pisa
QGIS code revision
d20c5b7
QGIS version
2.10.1-Pisa
QGIS code revision
d20c5b7
