What is the correct syntax for the geometry object's "intersect" method in ArcPy?
I'm building a script that utilizes the intersect method of the geometry class so that I can run an intersect analysis on individual polygons within a feature class. As stated here, "intersect (other, dimension)" requires two parameters, but there is no explanation as to what kind of string they are expecting for "dimension". What should I pass to the method for that parameter? I can't find any documentation to tell me
