What is correct Where Clause when using variable and Select By Attribute tool within
I have seen several similar posts related to this technique but I am still having issues. The following script is intended to select all points from one shapefile that are within the boundaries of a second polygon shapefile, then edit the number of points selected into one of the polygon fields. I have not been able to get the where clause statement to function properly although from the error message it appears to be correct. Both shapefiles are within a file geodatabase and feature layers where created for both in order to use the selection functions.
Here is the code:
arcpy.MakeFeatureLayer_management("treatment_maps",'maps')arcpy.MakeFeatureLayer_management("points_2014",'points')cursor=arcpy.UpdateCursor("treatment_maps")for row in cursor: map=row.getValue('map_name') where='"map_name"' + '=' + '\'' + str(map) + '\'' arcpy.SelectLayerByAttribute_management("maps","NEW_SELECTION",where) arcpy.SelectLayerByLocation_management("points","COMPLETELY_WITHIN","maps") count=arcpy.GetCount_management("points") row.setValue('DI_Count', count) cursor.updateRow(row)Here is the error statement:
Executing: SelectLayerByAttribute maps NEW_SELECTION "map_name"='Airport'Start Time: Wed Jan 15 13:00:56 2014ERROR 000358: Invalid expressionCannot acquire a lock.Cannot acquire a lock.Failed to execute (SelectLayerByAttribute).Failed at Wed Jan 15 13:00:56 2014 (Elapsed Time: 0.00 seconds)The treatment_maps features class contains polygons and counts (DI_Count) for points located within each polygon, which need to be updated. I'm hoping to get this script to work properly as I have around 100 polygons to update. Thank you for any help or advice!
