On QGIS 2.10, running on Ubuntu 15.04 Linux, I have a project file that has a fairly large number of mainly shapefile layers, which gets to 99% on the slider to the right of where it has a message saying 'Loading layer name of last layer' and then just hangs there, for a long period of time (sometimes an hour) before the qgis process crashes.
I haven't had this fault before, even when working with other projects with large numbers of complex layers, and this fault affects one particular project file for no obvious reason.
I have already tried a couple of different methods of resolving this, firstly by removing this last layer by manually editing the .qgs project file in a text editor, and secondly by disabling all plugins and restarting qgis in case it could be a plugin causing the problem. Neither of these affected the issue. If I edit the .qgs file to remove the last layer, the program hangs instead as it displays 'Loading layer...' for the preceding layer.
I have no reason to think that the data of any of the actual layers are missing or corrupted, and in any case if this had happened I would have expected the "Handle bad layers" message instead.
Does anyone know what kind of situation is likely to have caused this, or how to remedy it?
thanks, David
thanks, David
