What are the low cost options for converting FLEX API based web mapping applications
As flex is reaching the end of its life, I have one project to convert Flex based web mapping application to any other possible solution with minimum development effort and secure way. I believe Dojo based ESRI javascript API (as Siverlight direction is not clear either) will suit the need here (If company's policy allows cloud and then ArcGIS Portal can be leveraged too). But there are some suggestions around Geocortex framework or any microsoft based approach. The belief is Geocortex framework can give a secure and objects based development approach. But in one of the project I worked with Geocortex and multiple web mapping application- I found the development effort was so much underestimated under similar assumptions and project was running into mess. Any suggestion/ opinion/ experience will be helpful here. There is another web mapping application based on leaflet based ESRI API with Angular JS used by the organization and some of the client need can be microscopic too. Will Dojo be able to meet the need here?- Thanks
