<b stylemsobidifontweight normal><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Job Description<span><b>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>The role of the water balance and leak detection inspector is to carry out water balance and leak detection in the district metered areas DMAs on the instruction of the engineer through the supervisor and assist in attending to complaints of leaks as and when required by the engineer and supervisor. His main duties are to take readings of the meters in the selected DMAs and prepare the meter readings on an excel sheet for water balance purpose and installretrieve noiseloggers for the leak detection campaign followed by pinpointing of leaks.<span>
<b stylemsobidifontweight normal><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Major Duties and Responsibilities<span><b><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt><span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Assist the supervisor and support him in carrying out all his duties pertaining to water balance and leak detection in the selected DMA.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Prepare customers8223 listings on excel sheet and take initial and final meter readings of the meters in each DMA and prepare water balance report.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Prepare proper layout drawings for the effective deployment of noiseloggers in each DMA and checking for leaks in every connections<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Program install deploy and retrieve download display and interpret noise logger results.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Properly plan the route for meter reading and noise logger deployment campaign to reach the destination and complete the task within the shortest possible time.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Identify possible leaks from noise logger campaign and prepare to find leaks using all available equipment by correlation and pinpointing<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Submit report and finding of leaks for excavation and repair.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Physically carry and transport the leak detection equipment for site use and deployment ensure their security and clean and maintain them in serviceable conditions after completing field work.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Performs any other duties relating to water balance and leak detection work as instructed by the supervisor.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Consistently follow the schedule and program for carrying out water balance in DMAs leak detection campaign in DMAs and attending to complaints of leaks in order to achieve the target set by the engineer.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>The minumum target is to satisfactorily complete the water balance and leak detection campaign in all DMAs in the entire network at least once within 3 years from commencement data.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Ensure that all activities of water balance leak detection and attending to complaints are carried out in accordance to the procedures and flow chart as set out by the engineer and to complete them satisfactorily within the required period.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Raise and follow up work orders raised through JD Edwards ERP system.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Prepare excel sheet and drawings for the proper readings of the customers meters in each DMA for water balance purpose.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Conversant with the proper reading of all types of meters and possess skills in the use of all the available leak detection equipment in the WLDS section such as noise loggers correlating loggers ground microphone flow and pressure data loggers electronic listening sticks and etc .<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Prepare a water balance for each DMA on an excel sheet and submit report and findings to the supervisor.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Download the data recorded by the noise loggers and prepare an action list to identify and pinpoint suspected leaks using all available equipment.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Report on all invisible and visible leaks found and coordinate with the maintenance section to repair all visible and invisible leaks found within the period stipulated by the engineer or supervisor.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Report on the findings concerning unmetered customers faulty meters and illegal connections in the customers database and liaise with the relevant section for updating and replacement.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Liaise with the laboratory section to take water samples to check on the water quality<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Submit monthly report on his key performance indicator in terms of the number of meters read number of logger deployed and retrieved and number of visible and invisible leaks found and repaired per month and volume of water saved.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Compiles notes submit reports sketches and records of meters read noise loggers installed connections checked visible and invisible leaks found and repaired and all other work performed.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Performs other duties relating to water balance and leak detection work as directed by the engineer and supervisor.<span>
<b stylemsobidifontweight normal><span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Qualification Requirements<span><b>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Technical Diploma in an engineering discipline with five years experience<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Job Experience<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Minimum 5 years experience in an engineering environment.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Work Environment<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>80 Site Supervision 20 Office work.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt><strong>Other Significant Requirements<strong><span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Ability to work on site independently and be physically fit to work in hot and cold weather for extended hours<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Quick in learning new technical skills while on the job training for leak detection and meter reading and submit results on excel sheet and powerpoint.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Shall be in the age group of 2140 years and shall be available on call after duty hours<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Must possess State of Qatar Driving License.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Has reasonable command of English Language and be able to read write and speak in the language.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Good hearing capabilities with no hearing defects.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Keen attitude for operating leak detection and associated equipment and able to quickly acquire skills in using and maintaining new leak detection equipment with computer interface. Read and understand thoroughly the operating and maintenance manual for all equipments.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Work effectively with others as part of a team build consensus and maintain cooperative working relationships.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Has creative problemsolving abilities and personal initiative including the ability to carry out assignments with minimum supervision<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Physically fit and able to work long hours in harsh weather conditions.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Has general awareness of Health amp Safety requirements.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Able to work under pressure and emergency situation.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Ability to read and understand technical drawings of water network and pipe layout flow charts Oamp M manuals and procedures.<span>
<span styleFONTFAMILY 'Verdana''sansserif' FONTSIZE 10pt>Work fast with the computer and have knowledge of the latest version of the basic computer softwares and GIS for preparing drawings submitting reports and analysing results<span>
