voronoi / thiessen different CRS
I am having problems with thw following problem in qGIS: I try to create voronoi polygons based on a shapefile (points; standard WGS84). The newly created voronoi polygons layer seems to be ok for the WGS84 CRS. But when I swith into Pseudo Mercator CRS (3857) then the voronoi polygons are (of course) not representing the correct voronoi polygon layer and the polygons are not representing areas according to the neares points of the souce layer for that CRS.Is there a way, how to create new voronoi polygons layer based on the same source shapefile (standard WGS84), but so that the final voronoi layer would work correctly in the Pseudo Mercator projection? Thank you very much in advance ;-)
