VERO WORKNC V2017 R2-MAGNiTUDEصورة: http://www.hostpic.org/images/1705120624360100.jpg *VERO WORKNC V2017 R2-MAGNiTUDE |1.16 GB*WorkNC CAM software is the premier automatic CNC software for surface or solid models in mold, die and tooling businesses for 2 to 5-axis CNC programming. WorkNC is used by all western, Japanese and Korean automotive makers and well-known OEMs from a range of other industries. WorkNC is best of breed, complementary CAM software that enhances all design and manufacturing systems by providing the most reliable, efficient, easy-to-program cutter paths, resulting in unmatched productivity and safety.*WorkNC Licenses*The easy to use, high performance CAD/CAM solution for machining complex geometries, WorkNC combines ease of use, fast calculations, toolpath reliability...WorkNC ModulesWorkNC Add-onsMold and die makers, toolmakers, pattern makers, prototype makers, press and stamp toolmakers have long been acquainted with the powerful functionality of WorkNC.*WorkNC License Options*WorkNC Advanced FunctionalitiesParallel Processing of up to 4/16 process, Extra Workzone Calculation Module, allowing one extra Workzone to be calculating at the same time*WorkNC Translators*WorkNC translators solves compatibility problems with your customers' CAD systems. Reduce or eliminate data management issues between your customers & your workshop.*WorkNC2017* will demonstrate further enhancements to its expertize in efficient and reliable machining: toolpath precision, time savings, cost reduction and high surface quality. WorkNC 2017 integrates 'Advanced Toolform', the new technology from Vero Software, into its Parallel Finishing toolpath. Toolpath calculations are based on the real shape of the cutter and machining times can be reduced by up to 70%.Among the improvements expected by WorkNC's established users, the 'Dynamic Calculation Queueing' function allows operators to add calculations for newly created toolpaths, to postprocess them and check for eventual tool holder collisions without having to wait until the end of calculations currently in progress.*Download Link Rapidgator.net*Code:---------http://rapidgator.net/file/116b5c0386836e631933ed9922442d7b/VERO.WORKNC.V2017.R2-MAGNiTUDE.rar.html---------
