Using Python Search Cursor results to Select Features by Attributes
I would like to preface this by saying that I am very new to python and its capabilities. So my problem is that while using the in_memory work space I encountered some limitations in querying the minimum value for a field. My workaround for this was to create a dictionary, then use a the search cursor to find the minimum distance. My method returns the results that I am looking for but I have not been able to incorporate these results into my selection. Any help on this is much appreciated. Below is a snippet of the code I am currently using:
# Process: Near arcpy.Near_analysis(newStationLayer, targetPoint, "", "NO_LOCATION", "NO_ANGLE", "") nearDist = {} with arcpy.da.SearchCursor(newStationLayer,("OID@","NEAR_DIST")) as cur: for row in cur: nearDist[row[0]] = row[1] arcpy.AddMessage("Near distances: %s"%str(nearDist))arcpy.AddWarning(min(nearDist.iteritems(),key=operator.itemgetter))
lowestOID = min(nearDist,key=nearDist.get) arcpy.AddWarning(lowestOID) arcpy.SelectLayerByAttribute_management()
