I am using ModelBuilder for ArcGIS Desktop 10.2
I have the following code in the Raster Calcualtor which works in some cases but not in others.
Int(Con(IsNull("%A%")|"%A%"== 0,"%B%",float(%Max%) + "%A%"))In cases that A is Null I want the code to return the value from B however it is returning a Null. I suspect there is a flaw in the OR syntax but I can't work out what is wrong.
