Using OpenLayers 3 layer parameters to change layer controls
I have this JSFiddle that has a couple of layers and then a box after it where my opacity slider would be if all the correct external resources were loaded in.
In the 'Cities layer 2' layer parameters I have changed the parameters as so:
var vectorLayer2 = new ol.layer.Vector({ source: vectorSource2, name: 'Cities Layer 2', visible: true, slider: false});I was hoping by doing so when I initialise my layer tree I could query the layer and if the 'slider' parameter was set to true then it would show the slider, and if it was false then it would hide the slider but I'm not sure exactly how to write this?
This also might not be the best way to go around this so I welcome any other alternative solutions.
