I'm trying to use the Make Grids and Graticules Layer tool in ArcMap (have a ArcInfo license). I'm looking for a basic example like in North America.
eg.
eg.
- Start with empty map
- Set data frame to NAD83 UTM Zone 1N
- Create File geodatabase
- Create GridExample dataset in FGDB in NAD83 UTM Zone 1N
- Open; Make Grids and Graticules Layer tool
- Select grid template C:\Program Files (x86)\ArcGIS\Desktop10.0\GridTemplates\Quad_24K_NAD83.xml
- Select Extent, and Same as Display from drop down listthis sets Left: -5620263.767724, Top: -5620263.767724, Right: -5620263.767724, Bottom: -5620263.767724
- Select the GridExample dataset in FGDB for Input Feature Dataset
- Output layer is set automatically to Quad_24K_NAD83
- Run the tool
Executing: MakeGridsAndGraticulesLayer "C:\Program Files (x86)\ArcGIS\Desktop10.0\GridTemplates\Quad_24K_NAD83.xml" "-5620263.767724 -5275836.261749 5621263.767724 5276836.261749" C:\data\FGDB\Grids.gdb\Grid1 Quad_24K_NAD83 Quad_24K_NAD83 24000 -3.18645767674729E-04 "3 Centimeters" "2 Meters" PROJCS['GCS NAD 1983 CORS96 UTM Zone 60N (Calculated)',GEOGCS['GCS_NAD_1983_CORS96',DATUM['D_NAD_1983_CORS96',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',177.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]];IsHighPrecision NO_CONFIGURELAYOUT "PROJCS['NAD_1983_StatePlane_Hawaii_1_FIPS_5101',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-155.5],PARAMETER['Scale_Factor',0.9999666666666667],PARAMETER['Latitude_Of_Origin',18.83333333333333],UNIT['Meter',1.0]];-5123000 -12084900 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision" "GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000 10000;8.98315284119521E-09;0.001;0.001;IsHighPrecision" # # Start Time: Tue May 08 16:46:56 2012
The area-of-interest is much larger than the grid's intended area. Processing time may be long. Failed to create features in GRD_Grid1. Failed to execute (MakeGridsAndGraticulesLayer).
