Using Google Earth Pro style templates
When importing a CSV file into Google Earth Pro, I am asked if I want to apply a style template. I do. I'd like to be able to load a previously defined template rather than have to set the style options manually each time I load a file. After setting all of the options in the "Style Template Options" dialog, it appears to save two styling-related files: template_name.kdx and template_name.kst.
My template is fairly involved with a lot of subfolders, so manually setting it up in the dialog box every time is tedious. It looks like the basic settings are recorded in the .kst file. How do I apply a saved template to my imported records?
I would also like to set icon size (or is it scale) in the template. Currently, I can only control the icon image/href used. I would also like to set the label in the template. I have been unable to find docs/specs for the .kst format. Are there additional configuration options that can be manually edited in the .kst file that are not configurable from the dialog box?
Thank you.
