I ran across this slight issue when I was looking to access python installations from ArcGIS, QGIS, Anaconda, and x64/x86 versions. Sometimes, I find it easier to just pop into Windows' Command Prompt to do a little bit of quick work instead of opening up a GIS program or python IDE in order to access the interactive prompt.
Instead of navigating to each folder, setting shortcuts, or switching out the PATH environment variable, I wanted a different way to access each python installation via the Command Prompt.
