Using Bing Maps Quadkeys as Openlayers 3 Tile source
I have a number of tile sources which utilise Bing Maps' Quadkey system in an old Silverlight application and I would like to use them in a new Openlayers 3 map.
I have found several examples of functions which will convert these sources for Leaflet.js but the syntax is somewhat different for OL3 and reading through the API docs indicates that there is an ol.Tile.coord class but if I understand correctly this is an experimental feature and might require a custom build from the source code.
Can anyone provide an example of this type of conversion or indeed does anyone know if the latest (3.8.2) version of OL3 supports the quadkey method?
This is the Leaflet example:
var BingLayer = L.TileLayer.extend({getTileUrl: function (tilePoint) { this._adjustTilePoint(tilePoint); return L.Util.template(this._url, { s: this._getSubdomain(tilePoint), q: this._quadKey(tilePoint.x, tilePoint.y, this._getZoomForUrl()) });},_quadKey: function (x, y, z) { var quadKey = []; for (var i = z; i > 0; i--) { var digit = '0'; var mask = 1
