using arcpy.Merge_management
This script should make a field for all the feature classes in a geodatabase, populate the new field with the name of the feature class it's being created in, and then merge all the feature classes together. However, when I run the code I get the success message but only the first feature class features are in the output of the merged feature class.
import arcpy, os arcpy.env.workspace = r"J:\Non_RS_MXDs\Crown_Scrap.gdb" for fc in arcpy.ListFeatureClasses(): arcpy.AddField_management(fc, "DyRt", "TEXT", field_length = 30) with arcpy.da.UpdateCursor(fc, "DyRt") as cursor: for row in cursor: row[0] = fc cursor.updateRow(row) fClasses = [] i = 0 try: fcs = arcpy.ListFeatureClasses() for fc in fcs: print fc fClasses.append(fc) i = i+1 except Exception as err: arcpy.AddError(err) print err try: arcpy.Merge_management([fClasses], "Rts_8_15") print "merge: SUCCESS!" #count number of new features result1 = int(arcpy.GetCount_management("Rts_8_15").getOutput(0)) print result1 except Exception as err: arcpy.AddError(err) print "merge: FAIL :(" print err
