Using ArcGIS ModelBuilder with a "While" Iterator
I am struggling to get the ArcGIS ModelBuilder "While" Iterator to work as I would expect it. I have a hunch it's user error, but even reading the help hasn't seemed to get it working for me.
I have a simple model that calls a Python script that simple does a time.sleep(15) and then sends back the conditional parameter of "TRUE" or "FALSE" using arcpy.SetParameterAsText(1, "FALSE") or similar for True statements in an if/else statement. I've also tried every combination of TRUE, True, and true, as outputs from my Python script without success.
I can see in the results that my conditions are being set correctly:
Executing (While): IterateCondition FALSE TRUEStart Time: Tue Nov 20 16:10:06 2012Succeeded at Tue Nov 20 16:10:06 2012 (Elapsed Time: 0.00 seconds)and
Executing (While): IterateCondition TRUE TRUEStart Time: Tue Nov 20 16:26:41 2012Succeeded at Tue Nov 20 16:26:41 2012 (Elapsed Time: 0.00 seconds)but the WHILE Iterator continues to fire the sleep script, even if I change the output parameter of my script. Any ideas on why I cannot seem to get the sleep script to stop firing? What should I be passing from my SetParametersAsText() in order to get the While Iterator to stop firing the Sleep script?
