Use Feature Class "Name" from Iterate Feature Classes to Calculate Field with Model B
My goal is to create shapefile that contains merged feature classes from a geodatabase. I would like for there to be a new field in the resulting shapefile that contains the name of the original feature class. The tool that I have created is successful in merging the FCs into one shapefile however the "Name" field is blank for ever record.
The field that is intended to be populated is set up as a text field (length 50). I have set the "Name" variable from Iterate Feature Classes as a precondition to calculate field. My expression in Calculate field is "%Name%" with Expression Type Python.
What do I need to change to make this work? Thanks!
Link to Image : http://imgur.com/R0h4U78
