I have the following script that is used with a script tool to truncate each word in an input string and output the result to another field. There is an input parameter for the length of the truncation.
import arcpyarcpy.env.overwriteOutput = True# Prelogic used to pass through for calculating truncated name valuescodeblock = """def nmshort(stname,stnum): s = stname.split() s2 = s[:] = [elem[:stnum] for elem in s] s3 = ' '.join(s2) if s3 == stname: return None else: return s3""" # Finished code blocktry: # Set input parameters inFC = arcpy.GetParameterAsText(0) inName = arcpy.GetParameterAsText(1) inNameShort = arcpy.GetParameterAsText(2) inNumber = arcpy.GetParameterAsText(3) # set expression for field calculation to variables expression = "nmshort(!{0}!, {1})".format(inName,int(inNumber)) # perform field calculation arcpy.AddMessage("Calculating truncated strings for values in input name field") arcpy.CalculateField_management(inFC, inNameShort, expression, "PYTHON_9.3", codeblock) arcpy.AddMessage("Calculation complete")except: arcpy.AddError("Could not complete the calculation") arcpy.AddMessage(arcpy.GetMessages())How would I accomplish this same calculation using a cursor instead of CalculateField? I'm using ArcGIS 10.0 so I won't be able to use the data access cursors. I've used cursors successfully involving simpler expressions (one line'ers) but I can't figure out how to do it for multiple process steps.
