UpdateLayer & ApplySymbologyFromLayer_management doesn't seem to be working
I have been trying to update the symbology of my raster layer file but nothing is happening. I don't get any error messages from using updateLayer or ApplySymbologyFromLayer. It also printed symbology done like everything was succesful but when I open the .mxd to check, I don't see any changes in my raster. Can anyone tell me what I am doing wrong? Any help will be much appreciated
Also I have been trying to clip my raster IDW layer by the Tampa water feature class file with no luck. I know how to do it using the ArcGIS data frame properties but not with scripting...does anyone know how to script it?
#Working environment/Modulesimport arcpyimport arcpy.mappingarcpy.env.workspace = "C:\\GEP_662\\nyc_data.gdb"#Permit overwrite data arcpy.env.overwriteOutput = Truefc = "TB_CORE_DATA"#fc = "C:\GEP_662\jenn_test.gdb\\TB_CORE_DATA"fc1 = "Tampa_Water"rasterLayer = "C:\GEP_662\\Final_Project\\TOC_IDW1.lyr"#checks if feature class file exist#if arcpy.Exists(fc): #print "It exists!"#else: #print "doesn't Exist"arcpy.CheckOutExtension("GeoStats")#Create An Inverse Distance Weighting Raster Using Geostatistical Analyst Wizardarcpy.IDW_ga(fc, "TOC", "", "TOC_IDW", "1.45839999753707E-03", "2", arcpy.SearchNeighborhoodStandard(0.15416857624789992, 0.15416857624789992, 0, 15, 10, "ONE_SECTOR"), "")arcpy.CheckInExtension("GeoStats")print "Geostats Done"#The following code will load a TOC_IDW raster into a new raster layer, add it to the first dataframe of the specified mxd, and then save the mxd.#It will also add Tampa_Water & TB_CORE_DATA feature classes to map mxdPath = r'C:\\GEP_662\Final_Project\\Final_Project.mxd'rasterPath = r'TOC_IDW'rasterLayerName = 'TOC_IDW_LYR'md = arcpy.mapping.MapDocument(mxdPath)df = arcpy.mapping.ListDataFrames(md)[0]result = arcpy.MakeRasterLayer_management(rasterPath, rasterLayerName)layer = result.getOutput(0)arcpy.mapping.AddLayer(df, layer, 'BOTTOM')print " Raster Layer Done"#Add Tampa_Water & TB_CORE_DATA to mapReferenceLayer = arcpy.mapping.ListLayers(md, layer, df)[0]result1 = arcpy.MakeFeatureLayer_management(fc1, "Tampa_Water_Lyr")result2 = arcpy.MakeFeatureLayer_management(fc, "TB_CORE_DATA_Lyr")layer1 = arcpy.mapping.Layer("Tampa_Water_Lyr")layer2 = arcpy.mapping.Layer("TB_CORE_DATA_Lyr")arcpy.mapping.InsertLayer(df, ReferenceLayer, layer1, "Before")arcpy.mapping.InsertLayer(df, ReferenceLayer, layer2, "After") md.save()print 'Feature Layer Done'# Apply the symbology from the symbology layer to the input layerarcpy.ApplySymbologyFromLayer_management(rasterLayerName, rasterLayer)#Updates Layer symbologyUpdateLayer = arcpy.mapping.ListLayers(md, layer, df)[0]SourceLayer= arcpy.mapping.Layer(r"C:\GEP_662\\Final_Project\\TOC_IDW1.lyr")arcpy.mapping.UpdateLayer(df, SourceLayer, UpdateLayer, True)print " Symbology Done"
