Update Point ID as Start Node and End Node to Line through FME
I need your help to perform the below process in FME.
I have two layers: Pole Data (Point) and Cable (Line).
Cable has no ID.
I want to keep the Cable which is going through the Pole.Then make the cable as Single segment between two poles.Then I want to update the Start ID and End ID (Pole ID) to each segment (Cable layer).
Please share the design of workbench and what parameters I will use in each transformer.
