Unknown Error? - A Column was specified that does not exist
shps = [(shp1,"field1"), (shp2,"field2")] for item in shps: shp = item[0] field = item[1] for row in arcpy.SearchCursor(shp, fields='"{0}"'.format(field)): if row == MyInVariable: sql = '"{0}" = \'{1}\''.format(field,MyInVariable) if arcpy.Exists("fl"): arcpy.Delete_management("fl") fl = arcpy.management.MakeFeatureLayer(shp,"fl",sql) break del row The above code produces an error that states: "A column was specified that does not exist." field1 and field2 do exist as columns in shp1 and shp2 respectively. Where have I gone wrong? Thanks in advance!
