Understanding the polygon handler function in Openlayers
Using openlayers, I want to be able to draw one polygon on a map. After one polygon is drawn, I want an event to fire that stops any more from being drawn until a button is pressed. My current code allows the user to draw more than one polygon and I'm trying to figure out how to limit it. This is my current code:
// Add drawing layer analysisLayer = new OpenLayers.Layer.Vector("analysisLayer"); map.addLayer(analysisLayer);// add polygon drawing controlpolygon = new OpenLayers.Control.DrawFeature(analysisLayer, OpenLayers.Handler.Polygon);map.addControl(polygon);What I tried doing was adding a callback to the Control.DrawFeature function as follows:
// add polygon drawing controlpolygon = new OpenLayers.Control.DrawFeature( analysisLayer, OpenLayers.Handler.Polygon, {callbacks: { "finalize" : function(){alert('poly made')} } } ); map.addControl(polygon);This does not work, but it does not give me an error. I'm not sure how exactly to structure this function. I did find the function finalize in the documentation which is what I thought I needed, but I'm also not sure how to structure the callback.
EDIT:I'm starting to understand how these callbacks work. For example this detects that a feature has been added (using @Vadim's advice):
// detect polygon events function newPolygonAdded (evt) { alert('Polygon completed'); polygon.deactivate(); //stops the drawing } // add polygon drawing controlpolygon = new OpenLayers.Control.DrawFeature(analysisLayer, OpenLayers.Handler.Polygon, {eventListeners:{"featureadded": newPolygonAdded}}); map.addControl(polygon);What I still don't understand is how to limit the drawing layer from allowing more polygons to be drawn.
