I am trying to load a shapefile (http://dds.cr.usgs.gov/pub/data/nationalatlas/statesp020_nt00032.tar.gz) into PostGIS 2.0.1 using pgAdmin3's PostGIS Shapefile Import/Export Tool.
However its not allowing me to import the shapefile, showing the error messages below. Any idea what happen?
Output from PostGIS Shapefile Import/Export Tool
============================== Importing with configuration: statesp020, staging, geom, C:\gisdata\statesp020_nt00032\statesp020, mode=c, dump=1, simple=0, geography=0, index=0, shape=1, srid=4269 Shapefile type: Polygon PostGIS type: MULTIPOLYGON[2] Failed SQL begins: "SET CLIENT_ENCODING TO UTF8; SET STANDARD_CONFORMING_STRINGS TO ON; BEGIN; CREATE TABLE "staging"."statesp020" (gid serial, "area" float8, "perimeter" float8, "statesp020" float8, "state" varchar(20), "state_fips" varchar(2), "order_adm" int4, "month_adm"" Failed in pgui_exec(): ERROR: function addgeometrycolumn(unknown, unknown, unknown, unknown, unknown, integer) does not exist LINE 15: SELECT AddGeometryColumn('staging','statesp020','geom','4269... ^ HINT: No function matches the given name and argument types. You might need to add explicit type casts. Shapefile import failed.
