Unable to determine translation results - Universal Translator in MapInfo
I would like to export my table from MapInfo to ArcMap. Problem is that I get the error "Unable to determine translation results" and "FME EXE stopped working". I know that there might be many causes but do you have any clues? My table contains 227 georeferenced records (they are taken from multiple sources but finally each of them has his own shape on the map I think).
This is the log file:
Trying to find a DYNAMIC plugin for reader named MAPINFO' Opened native MapInfo fileC:\Users\Dell\Desktop\POWIERZCHNIE\Dotyk\Powierzchnie_dotyk.tab' Predefined coordinate system LL-WGS84' (WGS84 Lat/Longs) matches dataset coordinate system Read coordinate systemLL-WGS84' from MapInfo data file (parameters are: DT_NAME WGS84 PROJ LL MAP_SCL 1 UNIT DEGREE ) Opened mapping File C:\Users\Dell\AppData\Local\Temp\fme6C4E.tmp for output Mapping File Generation was SUCCESSFUL Mapping File Generation was SUCCESSFUL FME Session Duration: 0.4 seconds. (CPU: 0.3s user, 0.1s system) END - ProcessID: 8124, peak process memory usage: 36436 kB, current process memory usage: 36244 kB Feature Manipulation Engine 2012 (20120115 - Build 12212 - WIN32) FME_HOME is 'C:\Program Files (x86)\MapInfo\Professional\UT\' MapInfo.UniversalTranslator Permanent License. Machine host name is: Studio17 START - ProcessID: 7160, peak process memory usage: 21792 kB, current process memory usage: 21744 kB FME Configuration: Command line arguments are imut'C:\Users\Dell\AppData\Local\Temp\fme7238.tmp' LOG_STANDARDOUT'YES' FME Configuration: Reader Keyword is MAPINFO' FME Configuration: Writer Keyword isSHAPE' FME Configuration: Writer Group Definition Keyword is SHAPE_DEF' FME Configuration: Reader type isMAPINFO' FME Configuration: Writer type is SHAPE' FME Configuration: No destination coordinate system set FME Configuration: Geometry Handling Mode isClassic' FME Configuration: Current working directory is C:\Users\Dell\Desktop\POWIERZCHNIE\Dotyk' FME Configuration: Temporary directory isC:\Users\Dell\AppData\Local\Temp' FME Configuration: FME_HOME is C:\Program Files (x86)\MapInfo\Professional\UT\' FME Configuration: FME_BASE is 'yes' FME Configuration: FME_MF_DIR is 'C:\Users\Dell\AppData\Local\Temp/' FME Configuration: FME_MF_NAME is 'fme7238.tmp' FME Configuration: FME_PRODUCT_NAME is 'FME(R) 2012' System Status: 111090MB of disk space available in the FME temporary directory (C:\Users\Dell\AppData\Local\Temp\) System Status: 3941MB of virtual memory available Operating System: Microsoft Windows 7 Service Pack 1 (Build 7601) FME Platform: WIN32 Locale: pl_PL Code Page: 1250 (ANSI - Europa
