صورة: http://u.damasgate.com/001/4/b9fqiocob2p1xi8fo782.jpg 3ds Max + Vray: 3ds Max PRO in 6 hrs year of release: 2015 Duration: 6:42 Example files: NO Video Format: MP4 Video: AVC, 1280x720, 16:9, 15fps, 914kbps Audio: AAC, 22kHz, 23kbps, stereo About This Course: When I first made this course, it was to fill a void that I noticed in the arch viz industry. There are not a lot of tutorials out there that help you to learn arch viz from the beginning in a professional way, using the PRO software and a PRO workflow. So, I created this course, and I never could have imagined how popular it has become! It has also evolved a lot since that first time I published. Here are some key things to know: ORIGINAL COURSE teaches 3ds Max and Vray from the very beginning follows a project from nothing, all the way to the end demonstrates the exact workflow that I use daily as a practicing professional (thus the PRO part) uses my UI setup, shortcuts, etc (all downloadable for your use) shows you everything you need to know to create a basic project uses 3ds Max 2011, so as long as you have any version after that, you should be able to follow (updates have been made where necessary to account for changes all the way up to most current versions) contains 6 HRS of video from start to finish ADDITIONAL CONTENT brings you up to speed with the latest versions of the software and fills in the gaps where they exist more advanced techniques (i.e. HDRI lighting, etc) more advanced and complex projects currently two additional projects to follow along with, including an advanced interior and exterior. much higher production quality than original videos awesome new content being added regularly to make you aware of new techniques, software updates, etc. new projects coming soon الكورس لايحتوي على التحديثات الجديدة تحميل رابط واحد 1.8 GB https://public.upera.co/f/aGUYxulg أو تورنت بالمرفقات أو روابط مقسمة 500 MB بباسورد Code: --------- http://dl.softsaaz.ir/tutorial/Udemy - 3ds Max Pro in 6 Hours [softsaaz.ir].part1.rar http://dl.softsaaz.ir/tutorial/Udemy - 3ds Max Pro in 6 Hours [softsaaz.ir].part2.rar http://dl.softsaaz.ir/tutorial/Udemy - 3ds Max Pro in 6 Hours [softsaaz.ir].part3.rar http://dl.softsaaz.ir/tutorial/Udemy - 3ds Max Pro in 6 Hours [softsaaz.ir].part4.rar --------- باسورد فك الضغط Code: --------- softsaaz.ir ---------
