I am trying to run the VBScript 'round' function using the field calculator on a column for a numeric field that contains a large number of rows (> 500k). When I run the code on a subset of the field (~100 rows), it runs perfectly fine, but when I try to run it on the entire table I get the subject error. It says 'there was an failure during processing, check the geoprocessing results window for details'. Does anyone know what could be causing this?
This is an annotation feature class that I would like to keep in the ArcMap environment while editing to avoid having to import it back.
my code is in the field calculator is: Round([TextString], 1)
The annotation feature class is currently in a file geodatabase for testing purposes and then I will run it in SDE, ArcMap 10.2.2, Sql-Server, Windows 7 64-bit SP1.
