I've combined a from a geoserver WMS tilelayer (trails) seperately with a mapBox streets-baseic and mapbox sateline using LayerGroup to form two basemaps, "Streets" and "Imagery" available for a leaflet map. I'm wanting the WMS trails to become part of these base maps and not be an overlay users can control. I'm new to leaflet and am having trouble with ordering of the TileLayers within the streets layer group.
The map starts with the trails on top of the streets basemap fine. The trails will still display over the sateline imagery when switching to the Imagery base map. However, when the base map is switched back over to the Streets base map, the trails disappear.
I've tried to implement trails.addTo(map).bringToFront(); after the layer control, thinking it is an ordering issue and even played around with zIndex, without success. I've looked at the follwoing two posts. I could try to remove and re-add the layers each time the base map is switched, but it seems the answer should be simpler.
How to change layer order in leaflet.js
http://stackoverflow.com/questions/12848812/layer-ordering-in-leaflet-js
Can anyone tell me how I can order the combined tile layers within the base map?
Here is my code
"use strict";//map var map = L.map('map', { center: [IVY.default_latitude, IVY.default_longitude], zoom: 14 });//default basemap layer//street layer using mapbox basicvar mapboxbasic = L.tileLayer('https://api.mapbox.com/v4/mapbox.streets-basic/{z}/{x}/{y}.png?access_token=' + IVY.mapbox_api_key, { maxZoom: 18 });//City Trailsvar trails = L.tileLayer.wms('https://bloomington.in.gov/geoserver/publicgis/wms', { layers: 'publicgis:BikePedTrails', format: 'image/png', transparent: true, version: '1.1.1' });//aerial layer using mapbox satellitevar mapboxsat = L.tileLayer('https://api.mapbox.com/v4/mapbox.streets-satellite/{z}/{x}/{y}.png?access_token=' + IVY.mapbox_api_key, { maxZoom: 18 });//Base Map Layer Groupsvar streets = new L.layerGroup([mapboxbasic, trails]).addTo(map);var imagery = new L.layerGroup([mapboxsat, trails]);/*//experiment use bringToFront inside layergroup def - no differencevar streets = new L.layerGroup(); mapboxbasic.addTo(streets).addTo(map); trails.addTo(streets).addTo(map).bringToFront();var imagery = new L.layerGroup(); mapboxsat.addTo(imagery); trails.addTo(imagery).addTo(map).bringToFront();*///layer controlsvar basemap = { 'Streets': streets, 'Aerials': imagery};L.control.layers(basemap).addTo(map);// bring trails to front//base layer change method//only works when switching to aerials - not when switching to streetsmap.on('baselayerchange', function(layer) {trails.bringToFront();});//these don't make a difference//trails.addTo(map).bringToFront(); //trails.addTo(basemap).bringToFront();
Here is my code
