I am trying to build OSRM on a Ubuntu system (14.04 LTS, up-to-date, 64 bit), but I am getting a "Could NOT find OSMPBF" error.
First I followed the Ubuntu 14.04 instructions on the Building on Ubuntu page. This appears to have installed everything successfully.Next I followed it with the General Build Instructions:
git clone https://github.com/Project-OSRM/osrm-backend.gitcd osrm-backendmkdir -p buildcd buildcmake ..makeThis fails at the cmake line with:
-- Building on a 64 bit system-- Configuring OSRM in release mode-- LTO working-- Boost version: 1.54.0-- Found the following Boost libraries:-- date_time-- filesystem-- iostreams-- program_options-- regex-- system-- thread-- unit_test_framework-- Found Intel TBB-- Looking for Luabind...-- Found Luabind: /usr/lib/libluabind.so-- Looking for LuaJIT 5.2-- Could NOT find LUAJIT (missing: LUAJIT_LIBRARIES) -- Performing Test LUABIND_WORKS-- Performing Test LUABIND_WORKS - Success-- Luabind/Lua5.2 combination working with /usr/lib/x86_64-linux-gnu/liblua5.2.so-- Looking for STXXL...-- Found STXXL: /usr/lib/libstxxl.so-- OpenMP support found. Linking just in case for stxxl-- Looking for OSMPBF...CMake Error at /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:108 (message): Could NOT find OSMPBF (missing: OSMPBF_LIBRARY OSMPBF_INCLUDE_DIR)Call Stack (most recent call first): /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:315 (_FPHSA_FAILURE_MESSAGE) cmake/FindOSMPBF.cmake:46 (FIND_PACKAGE_HANDLE_STANDARD_ARGS) CMakeLists.txt:283 (find_package)-- Configuring incomplete, errors occurred!See also "/home/richard/osrm/osrm-backend/build/CMakeFiles/CMakeOutput.log".See also "/home/richard/osrm/osrm-backend/build/CMakeFiles/CMakeError.log".I can post the logs if necessary: CMakeError.log has a sequence of errors including undefined reference to pthread_create (doesn't appear to be related?)CMakeOutput.log is much bigger, but the last build command reported is
Run Build Command:/usr/bin/make "cmTryCompileExec3258574548/fast"/usr/bin/make -f CMakeFiles/cmTryCompileExec3258574548.dir/build.make CMakeFiles/cmTryCompileExec3258574548.dir/build...and it appears to have been successful.
Can anyone see what my problem is? Or where I should look? OSRM is new to me (hence my attempt to install & build, so that I can experiment with it), so I am not sure how OSMPBF fits in, or where to look. Also this Linux box has not been used for C++ dev work before, so it is possible a common tool might be missing? (I usually use Linux for Python dev). However the first step from Building on Ubuntu should have installed all the extras (cmake, boost, etc).
