trsp route between two points ( not edge to edge )
I'm trying to solve common problem, how to generate route/navigate between two GPS coordinates and not between two edges using trsp algorithm. I did read many articles here but i'm not sure how should i create temporary edge on huge psql database where even now routing taking several seconds and insert/update can take forewer.
Solution where i will navigate to nearest edge and then calculate distance between edge coordinates and destination coordinates is in my case not good b/c i'm trying to avoid one way streets and this solution is ignoring it.
Another solution i have is to find edge where both start(x1,x2) and end(x2,y2) coordinates are nearest to the destination GPS coordinates ( which does not need to be nearest edge ) and navigate there but found this edge is also very slow.
