I can't get GRASS to work on my system, and after doing some digging I think it is related to me using 64-bit python. I'm not really sure. I get this message...
This module requires the Numeric/numarray or NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries. when I try to import numpy from the GRASS shell I get:
ImportError: dlopen(/opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site- packages/numpy/core/multiarray.so, 2): no suitable image found. Did find: /opt/local/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site- packages/numpy/core/multiarray.so: mach-o, but wrong architecture I am using GRASS 7.0.0. I installed all of the required frameworks without a problem. I currently have python27-apple selected, but I have other versions on python from macports. Numpy imports fine into any version of python I select, but not into GRASS. Can anybody help?
