Transforming takes long time with st_transform
I have two shape files contains considerably large data. I exported them to my geodatabase(using arccatolog), which takes 2 days. The problem is their srid must be changed. So i tried creating new table from the tables i exported with sde.st_transform method but the query did not end. At the end 5th day i stop the query. In previous versions of the arcgis server i use shp2sde function from linux command line and give the srid parameter directly. But in 10.2 version i could not find such a functionality. So i got only arcmap&arccatolog and SQL options. I need to set srid of this shape files before i exported them. So what can i do?
Any help would be appreciated
