I don't have much experience with GIS.
Here's are my projections defintion:
private Dictionary CoordinateSystemStringDictionary = new Dictionary() { {CoordinateSystemStrings.EPSG2154, "PROJCS[\"RGF93 / Lambert-93\",GEOGCS[\"RGF93\",DATUM[\"Reseau_Geodesique_Francais_1993\",SPHEROID[\"GRS 1980\",6378137,298.257222101,AUTHORITY[\"EPSG\",\"7019\"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY[\"EPSG\",\"6171\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.01745329251994328,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4171\"]],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],PROJECTION[\"Lambert_Conformal_Conic_2SP\"],PARAMETER[\"standard_parallel_1\",49],PARAMETER[\"standard_parallel_2\",44],PARAMETER[\"latitude_of_origin\",46.5],PARAMETER[\"central_meridian\",3],PARAMETER[\"false_easting\",700000],PARAMETER[\"false_northing\",6600000],AUTHORITY[\"EPSG\",\"2154\"],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]"}, {CoordinateSystemStrings.EPSG3857, "PROJCS[\"WGS 84 / Pseudo-Mercator\",GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0,AUTHORITY[\"EPSG\",\"8901\"]],UNIT[\"degree\",0.0174532925199433,AUTHORITY[\"EPSG\",\"9122\"]],AUTHORITY[\"EPSG\",\"4326\"]],PROJECTION[\"Mercator_1SP\"],PARAMETER[\"central_meridian\",0],PARAMETER[\"scale_factor\",1],PARAMETER[\"false_easting\",0],PARAMETER[\"false_northing\",0],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH],EXTENSION[\"PROJ4\",\"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext +no_defs\"],AUTHORITY[\"EPSG\",\"3857\"]]"}, {CoordinateSystemStrings.WGS84, "GEOGCS[\"GCS_WGS_1984\",DATUM[\"D_WGS_1984\",SPHEROID[\"WGS_1984\",6378137,298.257223563]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.0174532925199433]]"} };And here is the method I use to apply them:
public Coordinate[] Transform(Coordinate[] points, CoordinateSystemStrings sourceCoordinateSystemString, CoordinateSystemStrings targetCoordinateSystemString) { CoordinateSystemFactory coordinateSystemFactory = new CoordinateSystemFactory(); ICoordinateSystem sourceCoordinateSystem = coordinateSystemFactory.CreateFromWkt(this.CoordinateSystemStringDictionary[sourceCoordinateSystemString]); ICoordinateSystem targetCoordinateSystem = coordinateSystemFactory.CreateFromWkt(this.CoordinateSystemStringDictionary[targetCoordinateSystemString]); ICoordinateTransformation trans = (new CoordinateTransformationFactory()).CreateFromCoordinateSystems(sourceCoordinateSystem, targetCoordinateSystem); return trans.MathTransform.TransformList(points).ToArray(); }In different calls to this method I do the following transformations
- WSG84 to EPSG:2154 : OK
- EPSG:2154 to WSG84 : OK
- EPSG:2154 to EPSG:3857 : Error.
{"Missing projection parameter 'latitude_of_origin'\nIt is also not defined as 'latitude_of_center'.\r\nParameter name: parameterName"}
I have a feeling like my EPSG:3857 string is not right or I am missing something.
- List item
