Topo To Raster executing but not creating the raster
I am using Topo to Raster by File (ArcGIS version 10.1) via arcpy on a large stream and point dataset. Arcpy runs fine and executes without issuing any error message, however it does not create the raster as it normally does. When I look in the project workspace I can see that the S File that Topo to Raster creates temporarely (before deleting it when execution is terminated) have been created and its size is slightly over 2GB.Not sure what is the S File used for as it is a binary and can't inspect it.Is there a limit on the size of the S File created by Topo to Raster?What can I do to get around this issue in addition to reduce the size of the point dataset?
Note that:There is enough space in the hard disk thereore the issue is not space; andThe tool runs ok when I reduce the size of the dataset (option which I would like to avoid).
