Here is my problem: First of all you have to know that I have ArcMap 10.1 SP1. My features are stored in Oracle 11g database in SDO_GEOMETRY format.
I have imported a layer of accidents location in ArcMap. So when I try to select all features included in a polygon (using the Select by Polygon), then too many features are selected. I mean some feature outside my polygon are part of selected feature.
So I draw a triangle on my map and I expect that all features included into the triangle will be selected. The result I obtain is all features included in the rectangle envelope of the triangle that are selected, which is obvious wrong.
Is someone can help me on this one?
You have to know that I was in SDE_GEOMETRY before and I wasn't had the problem when I tried to select by polygon.
Thank you.
Thank you.
