Toggling selected feature when using Node Tool of QGIS?
Does anyone know of a way, when using the Node tool in QGIS to edit a polygon, to choose or toggle which feature (within the same layer) is being selected if they share a boundary?
It seems to just select whichever feature is on higher order in the table...
It's not an issue if the feature has a boundary somewhere else that doesn't share a boundary with another object, but when using layers that have complete coverage (no gaps) there are often objects that are completely surrounded by other polygons and difficult or impossible to select/edit without first 'hacking' one of the surrounding objects...
In MapInfo there is a shortcut key (hold CTRL) and then as you click it will work it's way through all the objects in the layer at that location...
