Tilemill Queue Configuration?
I'm rendering about 104 projects on TileMill-v0.10.1 Windows 8.1 x64, by default TileMill will run 4 at a time, unfortunately if I run more than one at a time then project.failed file always becomes > 0 bytes on all running exports, which typically means missing tiles...
how do I configure tilemill to only run one at a time without doing it from command line, I just need it to finish an export before it starts up the next one, right now it matches the concurrency setting which I can't find where to change the default either...
The command line should work but it just hangs in windows, nothing in error logs... pretty annoying, works great on a Mac, bit of a nightmare on windows.
