I need to generate an atlas for each feature from a layer for reporting. There will be created a few maps. The centre of each map must be focused on each feature. In this task I use a predefined QPT template. In QGIS Composer Manager everything works perfectly. Then I save the QPT file as a template and I try to automate the process with a plugin using this function. It's based on this thread: Programmatically load composer from template and generate atlas using pyQgis
alayer=iface.activeLayer() # Add all layers in map canvas to render myMapRenderer = self.iface.mapCanvas().mapRenderer() # Load template from file myComposition = QgsComposition(myMapRenderer) template = 'atlas16.qpt' myFile = 'C://Users//maria//.qgis2//composer_templates//atlas16.qpt' myTemplateFile = file(myFile, 'rt') myTemplateContent = myTemplateFile.read() myTemplateFile.close() myDocument = QDomDocument() myDocument.setContent(myTemplateContent) myComposition.loadFromTemplate(myDocument) # Get map composition and define scale myAtlasMap = myComposition.getComposerMapById(0) # Setup Atlas myAtlas = QgsAtlasComposition(myComposition) myAtlas.setCoverageLayer(alayer) myAtlas.setComposerMap(myAtlasMap) myAtlas.setEnabled(True) myAtlas.setHideCoverage(False) # Generate atlas myAtlas.beginRender() for i in range(0, myAtlas.numFeatures()): myAtlas.prepareForFeature( i ) jobs = "D://Krzysztof//Skrypty//Archiwum//" output_jpeg = jobs + str(i)+ "_BMS_plan.jpg" myImage = myComposition.printPageAsRaster(0) myImage.save(output_jpeg) myAtlas.endRender() if os.path.isfile(output_jpeg) is False: QMessageBox.warning(self.iface.mainWindow(), "Uh Oh!", "Something went wrong, no image exported!") self.dlg.close()In the result I get some reports, but they look same - so the focusing on points isn't performed.
I suspected that I might be caused by the extent which is present in the QPT file. Then I changed my function, so that the extent will be adjusted for each feature. However, at the end I got only empty reports. The template content is as follows:
Does anyone know what might be wrong? Could you give any hints how a QPT template should be adjusted?
