Table Select does not work in Model Builder, when using parameter in SQL
I'm trying to create a model that uses values from a single table, in order to perform a different calculation for each raster in a file.Each raster is represented in the table by a row that contains the raster unique name (string), and 2 other fields with the numeric values for the calculation (slope & intercept).I use "Iterate rasters" to go through the files, and "Table Select" where I select the relevant row for the parameters, by using %Name% (from the iterator) = name (the raster name in the table).Doesn't work... the model gets stuck in the "Table Select" stage.Does anyone have any idea why?
Thank you!
